Engine swap firing issues
jgoddi256
I have purchased a 97 1500 sport 2wd that came with the 360 and previous owner removed and replaced engine with a 360 out of a 99 1500 4wd. The previous owner is known and trusted dodge diy mech but being up in his years he hurt his back and couldn't complete the swap. He says it's getting fuel but no fire. He also said that it coded something about a ground issue but can't remember exactly what. I've looked it over and all wiring seems in order. I have a98 and 99 with same engines that I've compared it to. 98 250k and is still a pulling beast. 99 just purchased with blown engine for parts. Any advice?
Sent from my XT830C using Tapatalk
MyOhFive
HEMI
Is the coil present/hooked up/working properly?
J
jgoddi256
Yes. It's there and connected. I've checked tining per TDC. On #1 in relation to distributor position and is good. plug/coil wires and firing order good. New plugs. With key in run position I have 5v at distributor.
MyOhFive
HEMI
Can you get a scanner on it again?
J
jgoddi256
I'm trying to locate one,
J
jgoddi256
I found the crank shaft position sensor was missing. Installed one and it fired right up
