Euro Quad Headlight Head Lamps Black
hemi1282
Arkansas
2016 Ram Tradesman
If it's the same ones from Depo I wouldn't bother with'em they fill up with water
WilliamS
Tampa FL
I am buying those but Im doing a projector swap into them, so the water isnt going to be an issue for me as Im resealing them.
Treburkulosis
Your High End Detailer
Haslet, TX
I was about to pull the trigger on these. I'm glad someone is asking. Sub'd.
jvoid4
jvoid4
Houston
I hope opening them is easy for you.
TSINND
Ram 2500 6.7
Look like a good start
TRXHemi
Sugar Land, TX
If you do get them, just seal them up yourself before installing....
jvoid4
jvoid4
Houston
I just ordered them. Ill see how they are and post on here.
I will more then likely seal them like TRXHemi said.
sbarron
Wasilla, Alaska
I'd only run them on dry DAYS.
Saving $ and battling ******-cheap lighting has never been an option for me.
sbarron
Wasilla, Alaska
Thanks for your opinion.
Seriously, wasn't trying to be glib. Just years of experience have taught me that going budget for parts that really matter isn't the way to go, especially if it's only for appearances sake.
whatTHEmilone
Grand Forks, ND
2013 Ram 1500 Express 4x4
Hemi 5.7l
Anyone have experience with these? I just found them on Ebay.
I know that some things on Ebay are hit and miss.
2009 2016 Dodge RAM 1500 2500 3500 Euro Quad Headlight Head Lamps Black | eBay
I have the same ones and I'm on my second set. The first ones got a lot of condensation in them, so I contacted them and they swapped them out. Apparently they have a 10 year warranty (at least the DEPO ones). The only catch is that you have to send the old ones back to keep the warranty. I just didn't send them back because it was $50 for shipping. Just recently I found TYC projectors on Craigslist for a good price so I'm going with those.
JGBimle
I used these for a projector swap. These are great for that because they're so easy to pull apart...literally. I didn't have to pry or anything just heated them and pulled them to separate which made them very easy to reseal as opposed to OEM Headlights I've done that I had a hell of a time just getting the lens off. These Headlights compared to my OEM black quads look like they came off a little tykes car as far as the quality differences between the two. If you're retrofitting I'd definitely get a set of these, however, I would never buy a set of these and run them as is. Definitely worth spending the extra to get OEM black quads.
Joey93
