Exclusive Discount on Westin Pro-e Electric Running Boards for Ram 1500/2500/3500
carid
Cranbury, NJ
Hemi 6.1
Today, we’re excited to introduce you to a game-changing add-on that will not only provide you and your passengers with secure and easy entry and exit from the cabin in any weather condition but also enhance the lower side area protection from debris, mud, and the elements.
Meet the newly released, stylish, and practical Pro-e Cab Length Black Electric Running Boards crafted by Westin for your 2011-2025 Dodge Ram 1500. This reliable upgrade features a 6-inch-wide, durable aluminum stepping surface with an impressive 300-lb. weight capacity per side. They extend automatically when the truck doors are opened and retract back when the doors are closed. Each Pro-e running board is equipped with two IP68-rated waterproof motors per side, ensuring dependable performance in all weather conditions. The integrated LED lights illuminate the 6-inch wide, durable aluminum step surface, ensuring enhanced visibility and safety.
Keeping your truck in pristine condition means protecting both its interior and exterior from potential damage. The Pro-e boards fit snugly against the body when closed, shielding the rocker panels from wear and impact. Plus, they serve as a convenient step to access the roof of your Ram, making loading and unloading cargo a breeze.
Westin® 29-23555 - Pro-e Cab Length Black Electric Running Boards
Notes:
Mounting brackets Included.
Features:
  • Fast and easy installation – no drilling required;
  • Automatically deploys when any door opens then retracts when doors are closed;
  • 2 waterproof IP68 rated motors per side;
  • Included LED lights illuminate step surface;
  • Sleek and snug up against body when closed while protecting vehicle rocker panels from potential damage;
  • 6" wide durable aluminum running boards;
  • 600 lbs. weight capacity (300 lbs. per side);
  • Corrosion resistant aluminum boards;
  • Hardware and mounting brackets included;
  • Available in black powder coat finish;
Westin running boards are designed for easy, bolt-on installation, and come with hardware and vehicle-specific mounting brackets included.
carid
carid
Cranbury, NJ
Hemi 6.1
From March 13, 2025, to March 25, 2025, take advantage of our exclusive online deal on premium Westin Pro-e Cab Length Black Electric Running Boards and save up to 10% off!
Special Offer Available Only on Our Website!
Don’t miss out, order now and upgrade your ride with advanced style, convenience, and ultimate protection!
If you want to learn more about Westin Automotive and explore the complete range of options suitable for your application, please click the link below:
https://www.carid.com/westin-automotive/
Whether you're after an aggressive styling, comfort-enhancing solution, or maximum versatility, there's always an option for you.
