Factory Aux Switch Panel
JGBimle
I have a 2015 1500 Express and am looking for ideas on switches for my front light bar and halos for my headlights. My switch panel that has the traction control and tow/haul mode has two blank spots in it but they don't appear to be usable for switches.
I have found this:
http://www.mopar.com/part/68247633AA?s=370488&i=5611436&b=ram
Which appears to be for models with more auxiliary equipment. Wondering if I could install this on my truck and use those switches for my lights? Or if there isn't any way to utilize my current switch panel?
Solej
I want to do the same thing, lights under the bed rails, halos and u-bars, maybe lights under the truck. I found a part number 56054539AA. Let me know if you come up with something.
Sent from my 0PJA2 using Tapatalk
WadXpress
HEMI
Go look in the 4th Gen DIY section their is a DIY thread on how to make the switches on the factory switch panel work
Solej
Thank you!! Did you do this?
R.L.K.
Bristol , Tn.
No problem Sir ! No I did not but I plan on doing it !
jknappen
Kentucky
The question is i believe can you buy the aux switch panel and use it to hook up extra stuff
R.L.K.
Bristol , Tn.
I was responding to the last part of his post to a way he could utilize his switch panel .
Not sure if you could just install another panel that's more populated? Don't see why you couldn't , if your crafty with wiring and have a good way to remove the ID on the switch ...
