I ran wires thru a cable that already went tru firewall, i poked a hole in the boot and snakes thruHello. What hole i can use to run se wires from engine bay to the cab through firewall?
Did the same on my 2021 Ram 2500 when I installed the in car warmer and ran the extension cord out to the front where the block heater plug is so I could plug them both in at the same time.I ran wires thru a cable that already went thru the firewall, i poked a hole in the boot and snakes thru
That’s what I used also.You can see where i passed mine through. It is actually the park brake cable pass through If you look straight up from there you can see another pass through with nothing in it. You can see the steering wheel linkage just to the right.
@rule18 Thanks for posting that thread!Hi, check out this old thread. This is a good place to start. https://www.ramforum.com/threads/ho...-plate-for-running-wires-into-the-cab.117923/
