FIX > 2013-18/classic 4th Gen USB Hub ... Battery to Keyed Power (For AA/CP wireless adapter)
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
So I recently upgraded mom's 14ram1500 BigHorn which had a previous 2018 UAQ radio upgrade (Android Auto/Apple Carplay) with a Motorola MA1 Wireless Android Auto adapter plugged into the USB Hub port. (or AAwireless adapter or CarLink for Apple Carplay)
What bit me in butt, was I overlooked the fact that the USB Hub in 13-18/classic trucks is powered directly off the battery vs the RUN or SW 12V Accessory circuit.
Meaning you have to manually unplug it everytime to shut off the truck to avoid draining the battery, which makes the Wireless adapter nearly useless IMO.
Here’s what I’ve got to fix it and move the circuit over to SW 12v … (remember for USB software updates to keep the truck running during it, low battery voltage will brick a radio).
The plan .... (Console equipped truck)
I will attached some schematics to help. Use them to identify connector pinouts/color codes used in the diagrams.
Inline-Console/Console Jumper is 8pin connector (2.8mm terminals) on the back of the console when you remove the rear panel. Pin 5 is power to the Hub… pin 7 should be to the 12v outlet next to it. (Pin7 it's Panel Backlighting ckt for the hub on 18/classic trucks)
>> Both are direct fed off the battery… Fuse (67) and Fuse (104) respectively. (See fuses --- Battery, diagram).
……… I was hoping to just swap pins 5 & 7 but it won’t work. Especially on 18/classic trucks... No No don't do it.
Next idea …
i350 INLINE-IP/CONSOLE/SEAT CENTER is a 14pin Hybrid connector at the front of the console with pin 1 being power for the hub & CDplayer if equipped (non console trucks have the connector under the driver seat)… This is fuse (67) also.
** Option 1 (not my favorite)
>>>> remove pin 1 at i350 going backwards and splice it into the forward 12v switched outlet in the console.
… That outlet looks to be fed off the Run/ACC circuit (Fuse 93) via the i410 Inline-Body/Console/Seat Center connector (under driver seat) at pin 13…
** Option 2
(Reference FUSES_RELAY---RUN_ACC diagram)
>>> The rear/back panel console 12v outlet is the one that can also be switched or direct off the battery depending on the position of the fuse (91)… Position 1 is direct to battery and Position 2 is off the Run/Acc Circuit (see owners manual also) via the i410 Inline-Body/Console/Seat Center connector (under driver seat) at pin 10…
>> Remove Inline-Console/Console Jumper pin 5 (Red Wire to the hub) and splice it into the rear 12v outlet (Light Blue/Pink Wire) at the inside back of the console panel. (Req's Move F91 to Position 2)
This is what I will ended up doing. (I was be able to remove the original pin/feed wire (Tape it out of the way) and install a 2.8mm Female terminal/lead to splice into the rear 12v Outlet.
*** You could also use a ScotchLok style splice at the 12v outlet and Cut off the original pin 5 wire/splice the pin 5 Pigtail to SW 12v feed wire but I'm not particularly fond of cutting off connector wires for splicing. ***
** Option 2 worked out great! The Motorola Ma1 switches on/off with the truck now and is fantastic with the 18/classic UAQ/UAS radio upgrade !!
For Jumpseat equipped trucks, you will have to
>>>> remove pin 1 at i350 (Red Wire) under the driver seat and splice it into the i410 Inline-Body/Console/Seat Center connector (under driver seat) at pin 10 or 13 … (Pink/Yel one side & LtBlue/Pink on other)
… That signal is fed off the Run/ACC circuit (Fuse 91) ONLY after moving the fuse to Position 2
Mike G.
M2 Mods (on Ramforum)
www.M2Mods4Ram.com
  • MEDIA-PORT---PREMIUM.pdf
  • FUSES---BATTERY.pdf
  • FUSES_RELAY---RUN_ACC.pdf
  • 2014-15 Inline-IP Console Seat Center i350.pdf
  • 2014-15 Inline-IP Console Seat Center i350 (1).pdf
  • 2014-15 Inline-Body Console Seat Center i410.pdf
Mpgrimm2
Mpgrimm2
SC
5.7L
Additional info/pictures
Mpgrimm2
Mpgrimm2
SC
5.7L
for additional info/pictures
Post 3
Mpgrimm2
Mpgrimm2
SC
5.7L
Post 4
Mpgrimm2
Mpgrimm2
SC
5.7L
Post 5
That's probably enough posts for any updates ... Carry on.
keaton68
texas
Do you have the part number of the usb hub that you used its just what I need?
Mpgrimm2
Mpgrimm2
SC
5.7L
keaton68
texas
Do you remember the part number for the usb hub that you used?
Mpgrimm2
Mpgrimm2
SC
5.7L
caulk04
Supporting Vendor
Mine as well, I hadn't seen this post until I asked about the media hub staying awake specifically with my MA1.
PaleFlyer
Charlotte NC
It's probably either a lack of caffeine, (or too much), but I can't figure out WHERE you did this wiring work... Is that the bottom of the back of the center console?
I'm having the same issue with my AAWireless, and they have a "start/stop" thing, but... It doesn't seem to work right. (Could be another sign I should have tried for Chrysler to replace my 8.4 versus me "fixing" the delam myself. I had a trip to the beach with the fam in a couple days, and didn't want the radio randomly calling the nanny the whole time/turning off the GPS... But now the damn LCD is starting to fail.)
Mpgrimm2
Mpgrimm2
SC
5.7L
Yes... Pop off the back panel of the console
hunterdan
SE PA
2019 classic
So, on jumpseat equipped trucks. It's a matter of removing the one pin, and splicing into the other wire under the seat?
jason1
US
This is older but new to me and this thread helped me out. I just got an android auto wireless USB adapter and wanted it switched off with key.
I have a '21 classic warlock with jump seat and this is exactly what I did. Moved fuse 90/91 to switched position. Pulled out the red pin 1 from i350a as seen in the last picture above and taped it up good. Then T-spliced in a wire from the i410 pink/yellow wire over to that pin one position. Taped it up. All under the driver seat. Super easy and works great.
Mpgrimm2
Mpgrimm2
SC
5.7L
Thanks for confirming this on a jumpseat truck. (I haven't had the opportunity yet to put my hands on one for this)
hunterdan
SE PA
2019 classic
This is basically what I ended up doing as well in my 19 classic with Jump seat. So far, no issues.
SSGTD
