Ken226
- Mar 12, 2017
- 2,293
- 5,933
- Location
- Washington State
- 2013
- Hemi
I thought I had this problem fixed a dozen times in the past 2 years, but it always returns.
I've reseated the fuses, tightened every ground cable, cleaned every cable connectors, used dielectric grease on every connection. The problem is intermittent, and the problem persists, no matter what.
Every time I do something, it stops for awhile. Fooling me into thinking I've fixed it. It always comes back. Worse in winter than when it's warm, and only when the headlights are off and the backlight is at it's full daytime brightness. If the headlights are on, the backlight dims a bit and no flickering.
I suspect a bad capacitor or similar electronic component inside the cluster itself. I've been reading through a few thousand posts on the subject, across various forums. This issue seems to be common across damn near everything Chrysler makes.
I've seen posts with this problem on Chargers, 300s, Challengers, Rebels, 1500s, 2500s, gas, diesel, etc. All they seem to have in common is the premium evic cluster.
I'm considering replacing the fancy premium cluster with the lower end 3.5" cluster, which are cheap and plentiful on ebay. At least temporarily, perhaps permanently. Then ill pull my cluster apart and start checking diodes, capacitors and any part involved with the change in brightness when the headlights are switched on.
I suspect some small voltage transformer or switched resistor.
Is the 3.5" cluster a direct plug n play swap?
