Fog lights replaced with new Bumper
Blackmagik90
Caldwell, ID
Hemi 5.7l
I just replaced my front bumper with a new one. The oem fogs would not work with the new bumper so I bought new ones from westin since it was a westin bumper. Well the problem I am having is that the wires for the fog lights got dirty from not plugging and thus blew a fuse. Anyone have a good idea as how to cover those? I was thinking of just cutting those plugs so I don't have that issue but I don't know if that will become an issue with making a check engine light come on. I have had an engine light come on because of the blown fuses.
TIA for any suggestions.
14 Lonestar
I would not cut the wires. Get some shrink tubing, seal the end shut and slide it over the plug and shrink it on the wire.
B
Blackmagik90
Caldwell, ID
Hemi 5.7l
14 Lonestar that worked beautifully btw. Just wanted to let you know your suggestion was super helpful. Also I would like to ask you, do you know if the active valence behind the bumper is needed to be kept installed or can you do without? I put it back on but could only get it installed on the bottom bolt so now it sits a little lower. I'm worried once the computer extends it during high speeds that it may be too low and it could hit something. Any ideas?
KAKA
