Front wheel offset not even after lowering with IHC kit.
Cardsin2005
After lowering my RCSB 4x4 with the IHC 3/5 kit. The drivers side front wheel is 1 inch farther in toward the engine then the passenger side wheel. Has anyone else experienced this? I know the IHC kit is designed to pull the front wheels in about 1/2 inch to give more room for wide wheels. That being said they should be the same from left to right. The wheels are aligned and have equal caster and camber. The eccentric adjusters are pretty close to the same on each side. The truck has never been in an accident and drives perfectly straight.
