Fuse and relay location for brake control 2015 2500 slt?
neverhme
Vermont
Guys been looking all day, watching youtube cant find this info is it on a pdf somewhere? I need to cross check for proper operation before picking up a 14k dump trailer.
HarryS
Air Force
Clovis NM
Everything is in the TIPM. All the relays are part of the PCB, and therefore aren't replaceable. The fuses are numbered 30, 29, 28, 81, 53, 11 and 87. fuse 11 is power for the trailer brake module, and 87 is run/start to the TBM. 30 is fused 12vdc, 29 is trailer tow relay output, 28 is backup lamp, 81 is right stop/turn, 53 is left turn/stop. Relays run park lamp, backup lamp, left lamps, right lamps, and power to the TBM.
