Gear switch out
Cmasterson
2014 ram 1500
Anyone switch out their 3.21 gears for 3.92 on Ram 1500? And any idea what I should expect to pay to have this done? Thanks
14hemiexpress
6.4l
I would try posting this in the engine performance section or maybe a mod can move it there. I know the reason you want the gears is probably for towing which is why you posted it here. If you have a 2wd I think it's somewheres just north of $2000 and 4wd I'm not sure because the word is the 14's ring gear isn't welded to the diff unlike some of the older ones. If it's welded you need a completely new carrier also and that gets expensive quick. I would expect anywhere from $2000 ish for 2wd to 4500-5000 for a 4wd. But the guys in the engine/perfomance section can give you a better ball park than I can probably.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Your best bet would be finding someone with 3.92 gears who wants to swap with you and just swap full differentials. Otherwise it's going to cost you a pretty penny. You'd be looking at $1200 or so for a 2wd and $3000 or so for a 4wd.
Jantelaw
