TC III
- Jun 5, 2019
- 143
- 83
- Location
- Clayton, North Carolina
- 2018 Tradesman 2500
- Hemi 6.4
New to the forum here. Have a few questions in regards to some possible modifications I'd like to do, but upon looking around my 2018 Ram 2500 Tradesman, I discovered some empty plugs. Can anyone identify what these are for?
1) Two identical plugs I found on each end of the rear bumper area. Are these for plugging in the rear cargo bed lights?
2) This plug was on drivers side in front of tire behind/attached to the bumper area.
3) This last picture I took under the rear seat where the bolts hold down the seat brackets. I plan on removing the bolts to change out the full bench and put in 60/40 seats. I read about others removing these bolts for modifications, but if you look at the picture there appears to be some sort of rivet? There's one of these at each end of the rear bench on the brackets. Is this attached to the floor? Anyone seen this? Everything I read about removing the rear seats was just removing the (4) bolts.
