gnition coil wire keeps popping off
Gaboy02
5.9l
Ignition coil wire keeps popping off
I just purchased an 02 Ram with the 5.9l and over the past 2 days i will be driving and the ignition coil wire keeps popping off of the coil itself. I was wondering if i need a new coil wire or something else is causing this to happen. Thanks for the help on my first post.
HemiLonestar
Navy Badge Coast Guard
MD
Either new coil wire or coil if the terminal is worn enough. Can you flip it around and see if it stays (don't know if the terminals are compatible to do that)?
G
Gaboy02
5.9l
the terminal is not reversible. I just think that the terminal is worn. I closed the gap a little bit on the plug side so hopefully that will hold till i can get a new wire. Thanks for the help
La ratilla
