GPS A-Pillar mount.?
zkahn
4.7L
I've seen the BullyDog and Trinity A-Pillar pods. Can anyone give insight to the details of the mounting plate?
What I'm looking to do is mount my Garmin Nuvi here...Has anyone seen a option for this or someone that has done this? Looking at the above image it looks like it would be doable but how is the bulldog mounted? Is there a dock like connector? The Tuners look to be roughly the same size.
I'd really like to get the GPS off the windshield. I've run gps power cable already through the A-Pillar and have it mounted at the upper left corner of the windshield(between a-pillar and stock oil change sticker location:crazy:)
Searched the google and here but could not find anyone that either has done this, info on the existing A-Piller mounts, or a ready made "universal" product. I did see one but lost it that looked to mount into the O.S. handle bolt location leaving the O.S. handle in-place. These had tube arms that extend a ways. This had either a ready made phone mount for various phone models and a X-grip like RAM mounts, but with two, even one, the O.S. handle would be useless.
zkahn
zkahn
4.7L
Yeah I've seen that one. My Dad (member Sweetee) has that. It's not bad I just like a clean dash, and close to factory installed look of the a-piller pods. GPS also feels closer on the left side. Reaching to the radio is a long reach as it is...I'm 6'1 and do not have t-rex arms.
john94si
Where did you find the first picture? the diablo mount?
HLram
2012 and 2007
Hemi 5.7 in both
Here is my BD tuner that I use as a gauge. The mount for the Diablosport I use is not mounted because I dont like the DS gauges, but it has a wider more square deal on it than this BD does. Hope this helps you. The actual mounts on both of them are made for any hole that is (I believe) a 2 1/16'' or whatever the common size for normal gauges are (temp, EGT, boost, etc gauges-old school type). they just push into the hole in A pillar. And of course the pics are sideways..... again....stupid iPhone.
daddy
luigi1285
L.I. NY
i am very interested in this. in my xterra it had a flip up pod that was built in above the radio. miss that
cgeorgemo
Joplin, MO
3.6 Pentastar
Would the position of the GPS beneath the A-pillar block the signal it receives from the satellites?
Has anyone tried holding it there and seeing if it gets good enough signal to lock to the satellites?
zkahn
zkahn
4.7L
Thought the same thing initially so I tried it out in that spot and it works with no issues.
Reticle918
