Guess going to join chevy forum to get answers
Where do wires run from black security box under drivers dash
  • Total voters
    19
Bulldog1
Arkansas
Black security box under drivers dash trying to figure out where wires run 4 wires into door
KeepRight
ExFalconFxr
US
EcoDiesel
Hey, I know for most of us, we want to help. Can you provide additional information. What truck are you working on? Give us pictures of what you can. Why would you need to access those wires. I don't care really the why - but what your doing helps.
Thanks
DirtyWipers
Kentucky
Since they're wires, I'd say they end up going to the battery somewhere but that could be anywhere. Best of luck.
BWL
Embrace the skeptisism
BC Canada
If it's factory then it runs to the bcm and not into the doors. If it's aftermarket then wtfk where the installer ran them, but you should be able to follow them if that's the case. Is it an alarm system or just a gps tracker as 4 wires isn't much? Kind of like the amount of information we have to work with. Maybe the chevy guys can shake their magic bowtie and come up with an answer. Is it just 4 wires into the door or 4 wires total out of the unit. Are you just messing with us and throwing out a brain teaser to make us pull panels to check for stuff that isn't there. I had a cel, but everything is still working fine. Could you ask the chevy guys why the light came on. I cleared the code and can't remember what it was.
Arturo Rojas
