Have 2.5" Level - should I raise the rear or drop the front?
Koko
Dudley, MA
Alright...my dealer installed a 2.5" leveling kit for me. Along with the leveling kit, I'm running 275/65R20 Nitto Terra Grapplers. When I went to pick it up it seemed to sit nose high. It's sort of bugged me all week. On a positive note it made my old 2005 Ford F150 Supercrew with Bilsteins set at the max seem low and small.
Anyhow...depending on what way I view my truck it seems nose high. I confirmed my suspicions with the tape measure. The front sits at approximatley 39 5/8" inches tall. The rear sits at 40 1/4". So the rear is just about 1/2" taller. To the eye...it looks lower.
Sorry (for the poor pics). Betters to come when I get her cleaned up and shining.
Oddly the tires look way better in person too IMO.
So my question is...add a 3/4 rear spacer? Or drop the front from a 2.5" to a either a 2" or 1.5" leveling kit? I know the rear is cheaper, but I want to do whats better.
Also, for those that had/have vibration with the leveling kit. Was it only in 4 high? Or was it in 4 auto?
K
Koko
Dudley, MA
I really didn't want to step up to 35's. Maybe next year. But the 34" Nitto's upgraded to will suit me fine. I'm going to be adding a plow to the fornt of my truck and I didn't want to deal with 35's rubbing once the front end squats. I think these tires fill out the truck fine.
Texasez
Dallas tx
I have the bilsteins at 2.8 and a 1" rear coil spacer. It keeps a little rake in. I think the stock tires look fine.
steadly2004
Lowell, NC
CTD 6.7
Add the rear spacers. Don't drop the front
Sent from my Nexus 4 using Tapatalk 2
fastNugly
Toronto, ON
2012 Dodge Ram Sport CC
Looks leveled to me with an ever so slightly bit of rake.
But if you are like me...then I would raise the rear
That is what I did on my 1500
I had a 1/4" rake but it looked TOO level for me and depending on where I parked it appeared nose high.
Now I have a 1" rake and love it :signs6:
jlb
MT
CTD
Mine came out about the same as yours, and that was with a 2 in level kit, and an Airlift 1000 already at 35 psi.
I don't know if you see any value in the airlift kit from a towing/hauling perspective, but for $100 you could justify it based purely on the fact that at 35 psi it raises the back of the truck (measured at the receiver hitch) approximately 3/4 in.
In answer to your 4wd auto question, anytime the 4wd is engaged you could potentially feel the vibration, so during regular operation in 4wd auto, your 4wd will not be engaged based on my understanding. It will only engage if it detects wheelspin, and at this point you could feel the shudder. However, I don't think many people on here have experienced the shudder, and lots of them are running Bilsteins at 2.8 which would increase the risk for shudder even higher than your 2.5 in spacer kit.
fastNugly
Toronto, ON
To add to this....once the Bilsteins settle from its 2.75" setting, you will more than likley fall between the 2.5-2.6" so it isnt far off from a 2.5" spacer.
I still personally like it set at 2.1" but thats just me
K
Koko
Dudley, MA
Thanks guys. 3/4" spacer was ordered from Top Gun Customz. Hopefully that will fix it. I may down the road add the Air Lift bladders, but I only really tow a light lanscape trailer with my zero turn mower. Couple times a year I'll load the bed up with dirt or stone but that's it.
Jstark45xd
I got a 2.5" leveling spacer set. My question is do I have to get an alignment after I put it on?
Thanks
Jeff
Sent from my iPad using Tapatalk HD
monettejb
2018 Hydro Blue Edition Ram 1500
Greenville, NC
Did you measure your rake before? I have 3" of rake, and because I tow a lot, I too will go with the 2" level with the 1.5" BL. Im just to scared to install the 2.5" and have the rear lowered some....
monettejb
Greenville, NC
Did you measure your rake before? Im curious mine has 3" of rake from factory. I think Im gonna go with the 2" because Im scared of this happening as well. Im gonna throw the 1.5" body lift on it also tho.
Jstark45xd
How important is the rake? Is it just for mpg/aerodynamics?
fastNugly
Toronto, ON
Rake is factored for many reasons.
Aerodynamics (for better streamline for MPG), towing (for squatting rears), etc
But this is why there are airbags (Air Lift 1000 among others) to aid in this rear sag.
Jstark45xd
Cool. Thanks for the quick response.
Fatboy1989
