HAVING PROBLEMS WITH AC VENTS??
Nealuss
5.2L 318
Just want to throw this out there for anyone with a 94-98 having problems with the check valve for their A/C vents.
For those who aren't aware there is a check valve on the vacuum lines under the hood which leads into the cab to control the ac vents. This valve failing is a very common issue and the OEM part was discontinued a long time ago. There was a different one sold by dealers that was actually for PT Cruisers and Neons but even that was discontinued over a decade ago. There are cheap aftermarket valves all over the place that barely work, but I could never find a permanent solution that lasted more than a few months at best...until now.
One of the technicians at the shop I work at suggested a Ford part of all things. Late model Ford trucks have vacuum actuated hubs that use a check valve to keep the hubs unlocked and it is perfect for our trucks. So far I have had zero issues and I have put at least 5 or 6 replacement valves in my truck.
The Motorcraft part number is YG-360 and it is $7 on Amazon. Hope this helps someone!!
MissouryDude
MO
Cummings Diesel
I have a 2002 Dodge Ram 2500 Diesel. Had issue with my AC only blowing up through my defrost. Turns out it was a vacuum issue.
Ordered a vacuum harness from my local dealership
Part #55056421AA for $22.35, took me 10 min. to swap out, fixed my issue.
N
Nealuss
5.2L 318
Good to know the diesel guys are still covered! Unfortunately everything for the gassers was discontinued years ago (or so I was told by my local dealer)
