HD Exhaust Tip
OC455
Central NY
Been searching the web and here, not really too much that I can find for exhaust tip for single exhaust 6.4L Hemi. Any suggestions that would work.
The OEM exhaust just looks blah....was kind of hoping for a clamp on style tip to dress it up a bit. Short of replacing the rear part of the tail pipe.
What size is the exhaust outlet?
If it's 3" you could go this route:
https://vibrantperformance.com/cata...d=188&osCsid=b09b83a6dc24393c6a7049ab56e07d41
It's the one I installed on my EcoDiesel. It's a 3" in x 3.5" outlet polished stainless
I matched it to how far the stock one stuck out. Being it's a weld on tip, I cut a slot in it with a cut off wheel and used a 1" stainless seal exhaust clamp to hold it on.
OC455
OC455
Central NY
.View attachment 236552
Is that the OEM pipe coming down? I just want to keep it simple without a lot of hassle and extra work.
Yes that is the factory exhaust, I did cut about 5" off the end so the stock pipe doesn't show easily on the inside of the tip.
That tip from Vibrant (1561) and the clamp(1167) I used are both rust free and the tip is still shiny.
Barrie Ontario
You’ll need to find one with a 3.5” inlet. I know mbrp makes a couple. I bought a cheaper rbp tip which is adjustable, but I wouldn’t recommend it as it had a bit of a rattle to it.
OC455
OC455
Central NY
Its angled down and it has an angle cut. Just want to dress it up. Not really finding anything I like. I just don't want it to look like a ricer mod, and certainly do not want ut to look like one of those ridiculous oversized diesel exhaust tips.040dc97d092475475d57572f45fedcd4.jpg
OC455
OC455
Central NY
@crash68 That one would work, might have to trim off a bit on the OEM pipe.
Ram75
South Jersey
2019 Tradesman
Did cutting the resonator off change the sound any?
Barrie Ontario
I already had the 14” magnaflow muffler replacement, but was just looking for a little extra growl and I’d say it’s actually a bit too much for me. I find it sounds cleaner but lots of drone.
Ram75
South Jersey
2019 Tradesman
Ok, appreciate the quick response.
OC455
OC455
Central NY
Im thinking I will find a straight cut, clamp style and leave it at the down angle instead of turning it out or trying to match how the OEM pipe is. Have to wait until pay day though.
OC455
OC455
Central NY
Got it on today. Cut about 8 inches off the OEM tube and slipped it over and clamped it tight. It has a 5 inch outlet, double wall stainless steel made by Gibson.6f96019b6e23019e218789e8b274d901.jpg
OC455
OC455
Central NY
It seems like it has a little more rumble to it now. I don't know how else to describe it. I like it.
It sticks out a little further than where the stock pipe was, but I think it looks ok.
No members online now.
sigsauerP938
