headrest monitor
sweetstang
Has anyone is talked a monitor in there factory headrest. If so how hard was it.
MikeG
Livonia La.
You can get aftermarket headrest with monitors already installed. I got a pair of Rockville with out dvd hooked to my double din
S
sweetstang
Yeah I have a power accoustik one and I dont like the feel of it, So I was looking to add monitors to my factory ones
98ksxj
Cummins
How did you run the wires to the headrests? Do you have to remove the seat-back?
baum
savage, mn
2015 Laramie
I was an installer for 10+ years in various shops. actually cutting in monitors to the factory headrests is not difficult. the biggest downfall to doing it this way is when you buy the all in one units like talked about above the wire goes through the bar and into the seat. when you cut them in like you are talking about there is no way to do this so you just put a small hole in the top of the seat under the headrest. i usually did it right next to the post.
most what i call "good" monitors one with a shroud that holds the monitor.
MikeG
Livonia La.
Just undo the bottom of the seat back and you can pass a small rod trough to pull your wire. I tied my power in the driver accessory power point.
