help ASAP please RE: engine oil cooler
ch312
i was recently in an accident with severe damage in my 07 hemi quad cab with tow package. i got my truck back and was just going over everything and noticed that my oil cooler (i think?) was removed and not replaced by the body shop.
here is a picture of my truck now and the radiator/cooler that's missing was where the red circle is.
can anyone please confirm that the cooler in this location was an fact an oil cooler as i plan on meeting with them tomorrow for another issue. i believe the ones pictured are: rad, trans, steering, and AC.
thanks in advance!
C
ch312
Everything looks good there to me...nothing looks missing.
thanks for the quick reply.
i swear there was a cooler there as it had an active leak that felt oily and the engine oil was dropping at a very slow rate. they did put new oil in the truck and there was zero engine damage...
far right is for AC
lower left is power steering
above that is trans cooler
biggest is the rad
tow package comes with an engine oil cooler, correct?
HemiLonestar
Navy Badge Coast Guard
MD
These trucks were never built with an engine oil cooler from the factory.
rdlangston13
Katy, TX
I've got nothing there in my 06 but if they sell some kind of cooler there I can add let me know!
Sent from my iPhone
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Isn't the oil cooler inside the radiator? That is how they do it on cars.
$miley
PCA4208
Albuquerque, New Mexico
Nope, only coolant, trans, and power steering. But oil coolers are easy to put in, you just need a special adapter to fit the hoses to.
C
ch312
thanks for the replies guys. i'm starting to think i'm crazy :anitoof:
i bought the truck used so the previous owner may have installed it. the oil stain is still outside in my driveway under that location and i remember from a couple months ago there was some oil just below the AC condenser. i believe it was the lower left on the cooler where it looked like the leak was.
the repair shop installed a different front piece that goes from side to side where the hood latch is.
where would the oil lines run from? i'd like to check these hose connections for fresh tool marks.
PCA4208
There's a little wire just hangin in your pic, there should be a little sensor on the end of it. It bolts up under your headlight bolt.
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
The black wiring within your circle.
Then look at the pic posted by HemiLonestar you can see he has a slight circle around where the ambient sensor is bolted up.
C
ch312
wow...talk about a good eye. thanks to both of you!
where would the oil lines run from the cooler to the engine so i can check it out?
Core-Lokt
2005 Ram 2500 4X4 ST
5.7L
Did any Ram pickups with the Hemi have an OEM engine oil cooler? I searched here and the internet and only found generic adapters or a kit for Chargers using water cooling.
Oh, anybody use one of the Derale kits?
emjohn4
Same question.
Wonder if the 2500 had a factory oil cooler?
HemiLonestar
MD
Hemi Charger police cars had an oil cooler, but no stock 1500 hemi ever came with one factory.
ChloeBrooks
