Help identify pieces from differential.
Wicklundwf
I changed the gear lube on my 01 1500 12 bolt differential and I found a couple of big pieces along with many smaller chunks/shavings. Looking inside it seems all there but......What could these be?
W
Wicklundwf
Pieces from differential
I was thinking that at first as well but the diameter is small like a bushing, it's 3/4" diameter, 2 halves. I've looked in books and videos but I don't see anything that small. Anyone any idea.
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
I initially thought bushing as well, but I cant think of what would use a plastic bushing in the differential.
One possibility is something from the clutch pack if you have the limited slip.
http://shop.advanceautoparts.com/wc.../19715/large/10724140_spi_708203_pri_larg.jpg
I don't remember from when I replaced the clutch pack on mine what it really looked like. I was in a rush to get it back together while I had access to a lift.
W
Wicklundwf
There's no clutch packs in there plus these pieces are metal. They are machined halves.
W
Wicklundwf
It crossed my mind, perhaps a bushing or shim for the pinion gear shaft?
Merc225hp
NA
truck
gas
Those are the anti rotation clips for the clutch discs, your lsd is about to explode if not dealt with asap.
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
if im not mistaken thats the same issue MANY 3rd gens ran into, its the clips, do not ignore that, you need to deal with that asap
