Help Needed Axxess ASWC-1 - UConnect 5.0
jkendall4
Kentucky
V6
I am currently installing an Alpine Halo9 ilx f258 in my 2013 Ram Big Horn. Has a Uconnect 5.0. I am pretty good to go with everything except two things.
1. I have never used Axxess ASWC-1 and when I type my information in on their website it does not give me wiring instructions. Does anyone know where I can find this or is there a how to?
2. The radio came with an orange with white stripe wire which I assume is the dimmer wire. Do I just hook that up to the Orange illumination wire? Thanks!
1500ram12
5.9L Cummins
Does the alpine have a 3.5mm jack in the back for steering wheel controls?
Yes the orange/white is dimmer and connects to the orange wire
2018 Ram 2500 6.4L Hemi Tradesman
J
jkendall4
Kentucky
V6
Looks like I have a rear aux input in the back.
1500ram12
5.9L Cummins
Do you have this connector?
then all you need to do is follow these
1500ram12
5.9L Cummins
That should be your steering wheel control input
1500ram12
5.9L Cummins
So itll basically be plug and play? All I will use is the red and black wire from the aswc-1?
Should be. You may have to "program" it. Just follow the instructions
J
jkendall4
Kentucky
V6
Started a new forum but probably should have came here first since a lot of you guys have the alpine.
Quick question I have a 2013 uconnect 5.0 no alpine and I am connecting a halo9 up. I got everything I needed from crutchfield but I’m getting no power to my head unit. Did anyone else have a similar problem?
any ideas?
1500ram12
5.9L Cummins
What adapter did you get to go from the factory wiring to the radio?
