RAM-pagingMN
like the title says, im putting new gears the same time i lift it. i have a 2017 6.4 hemi 2500 with 4wd. am i correct in assuming the front diff is also 11.5 or is it smaller? im going with the 4.88 gears from G2.
Rear diff only is 11.5". Referred to as a "Dana 80". It's made by American Axle tho, so it's not a Dana technically. Please report back on your RPMs vs MPH in 5th and 6th gears when you can. I don't feel like doing math this early. Lol. Thanks. I am considering 5.13s if they'll fit. I have same damn truck as you with 4.10s now.like the title says, im putting new gears the same time i lift it. i have a 2017 6.4 hemi 2500 with 4wd. am i correct in assuming the front diff is also 11.5 or is it smaller? im going with the 4.88 gears from G2.
