Help please
S
Sanity66
Houston
I have checked all fuses. I've looked for loose connections. I've looked for bare wires. Somehow I was able to get three codes. 920,921,999
S
Sanity66
Houston
I have checked everything that I can think about
Scottly
Safety Harbor, FL
HO 6.7 Cummins
That means the ECM isn't communicating with the other modules. Check the wiring to the ECM, and check the ground connections. It is possible that your ECM is toast.
S
Sanity66
Houston
Ok so is that possible to happen with no warning. I drove the truck to drop wife off at work. Parked it. Came time to get her, truck wouldn't start
S
Sanity66
Houston
I unplugged and replugged the connections to the pcm and something happened. I checked the inside, all gages working , and she fired up thank God
S
Sanity66
Houston
Please I need help as this is our only vehicle, thanks
Spike95
Houston
If unplugging it and plugging back in helped the situation, then there’s a good chance the issue could be at or near the plug that you were handling. Check for any moisture or corrosion inside that plug. Check all of the female terminals and see if any of them look looser than the rest. If it is running, wiggle test the harness near the plug and see if that makes the problem come back. Check every ground connection you can find. If one of them is even the slightest bit loose or dirty, it can cause all kinds of issues.
Next time it does this, you might also try disconnecting the battery ground and then reconnecting it to see if it resets something with the computer.
tourqued
Cross roads
5.9 diesel
You prolly have a broken wire at or near one of the plugs .
The grounds on these trucks are truly badly engineered too.
If you have not done so, it is worth to redo them all.
If you live in the rust belt, most are not even working.
pacofortacos
I would disconnect the battery and turn the key to start for 30 secs.
Then take and unplug and plug in the PCM plugs about 5-6 times - you might need to get some gentle contact cleaner if this doesn't help.
S
Sanity66
Houston
Thank you all for your replies. Turnd out to be a bad ecm/pcm
S
Sanity66
Houston
I ended up buying another pcm/ecm.
Truck is running fine now
joshhhh
