Help with nitvision hid kit from retro-solution
AKreed22
AZ
4.7 v8
whats up guys i got my kit in the mail and have everything hooked up for the headlights. ballist connections and the headlight conections are all hooked up and the right fit. when i turn the light knob i get a lamp out warning light and the lights dont come on. they didnt come with any directions so im just going off how i installed a kit on my other car...any help is appriciated in advance!!
LB3711
Trumbull, CT
3.6L V6
i dont know 3rd gens but I think they need a resistor on each headlight to work properly
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Check your grounds, make sure they are to bare metal.
Check the polarity on the ballasts. It is possible to plug them in backwards (I've done it a few times!)
Check that the power wire to the battery is snug.
A
AKreed22
AZ
4.7 v8
the only thing is this kit doesnt have any grounds, jumpers, or lines that need to go to the battery, i used everything that was in the box and everything only plugs up into a certain spot. Has anyone else used the NIGHT VISION kit from retro?
A
AKreed22
AZ
4.7 v8
ok never mind my mind was blown when there was not other wireing included, but i looked at the kit on their webpage and i think they forgot to send me the relay wireing. bout to hit em up right now.
reddot
Wolf Point, MT
5.9 cummins
check that fuse also, ive had issues with it on one of my many kits. any pics of what you got?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
when the order was placed, did you select your truck in the vehicle application drop down box?
TheMaddog
DFW
Don't worry, once you get it, it'll be good. I ordered projectors and they forgot to ship them, but he responds really fast. And he'll get you squared away.
Sent from my droid killing iPhone using Tapatalk
A
AKreed22
AZ
4.7 v8
todd got back to me and they sent the other harness in the mail today...just got the truck detailed so ill put some pics up after the install...anyone know if the fog lights are plug and play or do they have to be wired to the battery as well?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
35W kits are pnp
A
AKreed22
AZ
4.7 v8
confused
never installed a kit like this can anyone give guidence, its the night vision headlight kit. hope the pics post. photo.jpg
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
What I did is to start with that top one, the one that you have to hook up to your battery. Run the long tail end over to the passenger side headlight. Take out each headlight form your housing and install your hid bulbs in the headlights and the rest should come easy. The ballast go to each of the headlight wires so just take your time to install them and you should be good to go.Hope that help.
A
AKreed22
AZ
4.7 v8
So i dont use the extra jumpers?
05singlecabHEMI
Lilburn,GA
I made this video a while ago, it might help
player.swf
A
AKreed22
AZ
4.7 v8
05singlecabhemi got me straightened away, appriciate the time and effort to help out bro!
bmireault1980
