hid lights blink
Thomas
fort worth
What resisters and compositor do I need to fix The blink and lamp out?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
bixenon or hid low / halogen high?
HemiBabe
DFW
JJ will git ya fixed up!
Thomas
Thomas
fort worth
I alreadyhave a have a relay harness is yours different from others
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
more than likely! yours is blinking, mine fixes that. :D:D
Thomas
Thomas
fort worth
I guess I should have said I have not install the relay harness I am running at of the park lights
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
um........say what?
Dude - install the harness, run it off of the heads.
Thomas
Thomas
fort worth
I'm going to bed I thought I need resistors to clear the lamp out and I was gonna do it all at once
HemiBabe
DFW
You may have the wrong set, a lot of universal kits won't work on the Dodges, they will blink like what you're saying yours are doing... the kits JJ sells are guaranteed not to flicker
Thomas
Thomas
fort worth
well I will be ordering jj's kit. The one I had would not even reach.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
d'oh! typically I tell customers to run it from the fuse box, there is a jumper there. Gives you a few more inches to work with.
Thomas
Thomas
fort worth
Jj do you have a kit so my high and low would be hid
HemiBabe
DFW
Yes he sure does, I have it on my truck with 6k
[tapatalkin]
Thomas
Thomas
fort worth
**** i'm probly going too order new everything win I get paid again
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I do!
Check out the 35W or 55W kits from Retro-Solutions Store
Use code "JJ" again for 10% off!
You'll need a 9007 kit with the 02-05 harness. :D
joshhhh
