HOOD LIGHT KIT
Ramman70
Coshocton, Ohio
I have read the other posts and still can’t find an under the hood light assembly for a 2020 Ram 1500 Long Horn. I can find 2017-2019. Can anyone help me? Thanks!,
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Under hood lights were no longer equipped after 2017. Some early 2018 trucks came with the cutout in the underhood insulation to easily add the light. All 2018s had the body harness plug on the passenger side firewall.
Starting in 2019 the plug was no longer in the harness. You will not find a listing for an underhood light for 2019+ because they were not equipped nor can be with the light kit.
Power Crimp
New Jersey
I have a 2018 Express and I don't see the plug with the cover for under hood light.
Atcer2018
Virginia
If the Express was optioned with the under hood light the harness will be on the passenger side near the hood hinge just below the windshield cowling.
Power Crimp
New Jersey
Yes thanks I've tried to find part number to order missing harness anyone know the part number.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
I'm curious, What month/yr was your truck built?
Maybe the Express used its own stripped down harness and that's why it doesn't have one. The plug is just 2 wires, a power and ground.
You could buy a kit for say a 2016
mount it on the passenger side
the kit has its own switch, similar to a mercury switch, using a ball bearing
OR
make up an LED light string, similar to what you would use for Bed Lights
you can rig a switch under the hood, hooked to the fuse box or battery
noraa73
