Growy16
Evening. I have a 2017 RAM Limited Gen 4 with air suspension. I'm in the UK so timelines will be a little misaligned but I wanted to ask for help with AlfaOBD. I purchased the OBD Link MX+ and have the app in both Android and IOS. My preferred is IOS. I have uploaded the designated RAM software and I can (could ) see the DTCs. I have cleared those but the 'Service Air Suspension' notice is still on the screen. Prior to this I replaced a split airbag, removed and tested the compressor and repaired damaged wiring on it, replaced it, purged the system and recharged the nitrogen system to 180psi. Following the recharge, after about 10 minutes I heard the compressor start and the bags inflated to what I assume was Entry/Exit as it lifted it about an inch off the bump stops (rear only). However, nothing else currently works. I purchased the OBD Link as I had read that I could use it to manage the air suspension, however, all I can find is diagnostics and, via that, as mentioned, DTCs. I can get information that with my Snap On reader! I messaged OBD support and all I got from them was that they support OBDLink, not AlfaOBD which just confused me more, especially when they said that I should email [email protected] for Alfa support! So, my question is; How do I access the parameters and controls for the air suspension through this medium in order that I can reset the system and get to use my truck again? Any and all help to get it off its knees and clear this screen would be very greatly appreciated. All the repairs are complete and I am simply frustrated that I cannot get the system working again. I realise that you may have covered this topic before but please bear with me....TIA
