I think my HEMI is burning synthetic oil??
CanadianHemi
Nova Scotia
Hey guys, I decided to check my oil today since it was a nice day out and I'm due for an oil change in another 2000 kms. Come to find out, my dip stick was reading very low, just below the add oil mark! Not a good sign.. I have been getting regular oil changes at the mechanics recommended 10,000 intervals.
I have been using Casterol Full synthetic and WIX filters. I had a Dodge tech look over my truck and scan it prior to my build, and recall him mentioning how great the engine condition was.
Last time prior to this incident I checked the oil after around 8,500 kms, it was down about 1L. Truck doesn't smoke, no blow by, no oil drip spots, nothing.. Is this a normal thing with a HEMI using full synthetic? Could the cold weather be a variable? This is my first performance type engine and also my first engine using synthetic.
CostaRam
Costa Rica
I need to use High Mileage oil on my 98 5.2l Dakota to avoid oil leaks and burning.
You may give that a try!
Chris
crazykid1994
My old VW didn't like Mobil 1. It used to burn a quart every 4-5000. I switched out to some European blend with different additives and it didn't even burn enough to tell on the dipstick after 10,000. I even ran 5-40 Mobil 1 over the 0-40 European blend and it still burned it somehow
CanadianHemi
CanadianHemi
Nova Scotia
What oil do you guys recommend? I don't really want to spend a ton on Royal Purple, plus it's kind of hard to get where I am at. The previous owner always used Casterol Edge Synthetic, 5W20, so thats what I've just been using. Should I possibly switch up the weight as well? I've read that a lot of people's HEMI's don't like the Mobil 1. I've asked a few of my third gen friends and they all think that my situation is NOT normal. They hardly burn any oil, and figured that my valve seals could be going. I've had engines use oil before, but not this much, especially to be considered normal.
crazykid1994
I think a lot of people like penzoil platinum. That's what I'm looking at switching to. You can run 5:30 according to quite a few people. I may switch as well. But 5:20 should be fine
ST-8
He's serious. Mines always burned oil since I've had it. Probably a tad worse than when I bought it but 7 years I'm not complaining. My truck will burn about 3qts in about 5-6k miles, I've thought about running a redline or royal purple one time but 10qts ain't cheap lol.
Andrew09HEMI
A lot of modern engines burn oil between changes. Hell, Porsche motors have been doing it for years as well as BMW. They both tell owners to check oil weekly. Just the nature of the beast. Shorter trips will burn more than longer trips. Really not a big deal just check your oil
usaf2006
North Carolina
Mine doesn't burn more than .5 of a quart over the course of 5,000 miles when driven normal. If I drive it like a race car, then it'll burn a quart or more.
HemiLonestar
Navy Badge Coast Guard
MD
It will be. Only reason OEM went to 5W20 that year is because they wanted the same oil for all the 5.7's and 05 was the year the LX platform came out with the MDS 5.7 (which does require 5W20 to function properly). Specified oil for the 5.7 in the Rams for 03-04 was 5W30 and the 05 1500 engine is no different.
CanadianHemi
CanadianHemi
Nova Scotia
Could Synthetic be causing the oil to burn more? I was told by a few to switch to Royal Purple, but I don't want to spend a lot on oil, if it's no difference between my Synthetic Edge. I was also thinking of switching the weight to 5w30 as well.
HemiLonestar
MD
I don't know that the synthetic is causing it, what I have noticed if you flog a hemi it will burn oil lol
Ram1500hemi
Any modern car that is not boosted burning oil is just craziness to me.
You have all the technology and money in the world, you charge us an arm and a leg for these pieces of crap, and you can't stop them from burning oil? I just went to the auto show and the new hemi trucks fully loaded are 70k. 70k! That's a cheap house! And you can't keep it from burning oil?
Complete bs.
Then bmw and porsche? Those cars actually do cost a nice house. Can't stop it from burning oil. What a joke.
ST-8
I had a ecoboost f150 riding my ass at night so I just hit it an all I could see from the f150 headlights was smoke trailing from my bed, never realized it was that bad...
Csanders1992
Are you being serious or joking?
How could this be?
The GM twins were the same way on the 07-13 motors. Not sure about the newer engines. It was because the engine would use oil during cylinder deactivation
Ferro
First of all if your mechanic is telling you to change the oil every 10,000 miles I would find another mechanic.
New Rhino
