Idle RPM
Hot Ducer
Atlanta Ga
Where does your truck idle? Recently, ince it gets to temp my truck will idle as low as 500 RPM isn't rough and doesn't "search" for idle speed, but I dont remember it being that low before.
2003 1500 QuadCab 5.7 4x4
Harley Harrold
USAF Ret. 36+ years service
Navy Badge Air Force Firefighter
Mississippi
5.7L HEMI
My 2007 Ram Quad Cab 5.7L Hemi idles at 800 rpm at normal operating temp. It will sometime drop down to 600 rpm when hot, and idling for a while, but always runs smooth at that idle.
Ajwalk2008
Springfield, il
I'm having the same problem. Mine feels like it has a miss but coil packs test good and has had a tune up in the past 3 months
Ceri
Idle can be affected by a dirty throttle body. Its minor, but has the greatest impact at low rpms and idle. 600 is typical for a fully warmed up hemi.
Hot Ducer
Hot Ducer
Atlanta Ga
Good call, pulled it apart today and my throttle was dirty as crap! Chock full off sticky residue. Cleaned it all up and it's sitting between 600-700 now. Thanks for the input. The gas pedal is more responsive now. Not greatly, but noticeably enough.
Ceri
Sweet! Love that kind of job. Getting a little dirty and doing it yourself. Inmediately resolved.
Hot Ducer
Hot Ducer
Atlanta Ga
Yep, just wish I had woken up early and done it before it got to be 95 degrees outside.
Ajwalk2008
Springfield, il
I've done that already and it was no help. Could it be a bad injector?
Ceri
I couldn't rule it out, but I'd guess its due to air intake, emissions system, or vacuum issues. If there's no roughness to the low idle, then I'd lean away from a dirty injector. No codes? Brakes working 100%? If you had a vacuum issue, you might feel it in decreased braking performance. Air filter looking good?
Ajwalk2008
Springfield, il
K&n cold air intake cleaned every other oil change. Braking hasn't changed since I got it back at the beginning of the year. No codes no nothing. Cleaned the throttle body. Replaced plugs and wires about 2 months ago.
Ceri
You might start a new thread and see if anyone else has an idea then. You could try replacing the PCV valve. Its easy and only about 20 bucks. I'd recommend it around 100k miles as regular maintenance anyway. Not saying that will fix it, but it couldn't hurt. I'd also mention the EGR valve, but its more like 40 and takes a little bit longer. You could still do both in about an hour. I assume you don't have a tuner installed because many of them can manually adjust the idle rpm.
Ajwalk2008
Springfield, il
No tuner as of yet. I'm at about 90k so I might try the pcv valve. Thanks for the help ceri
Ceri
You may try resetting the adaptive memory too. With summer coming on full strength, it might need to relearn. Its a free shot in the dark.
Ajwalk2008
Springfield, il
I actually did that monday night since I put my cat back on over the weekend noticed a little difference in the idle. Constantly staying around 600-650 now where it was at 500-550 before
Ceri
Sweet! Sound perfect, in more ways than one I trust.
Jeff Strader
"GreyGhost"
Norman Oklahoma
A 5.7 Hemi's PROPER idle range is 600-625rpms, while in gear, and at a full stop. One person above, said 800rpm's is the proper range (TOTALLY INCORRECT). If your 5.7 Hemi is idling at at 800rpm's or higher, then your having either a fuel/air delivery system issue or your Cataletic Converters are clogged up, or in the process of clogging up, making it hard for the engine to properly dispel the exhaust gases, thus causing excessive engine back pressure, in which is forcing the engines ECM (computer), to try and compensate for the problem. ALL 5.7 Hemi's are pre-set by the factory to run at 600/625rpm's (while not under load) while engaged in gear, at a full stop...........5.7 Hemi's idling at 500rpm, will generally cause the Alternator to dispel the improper voltage output (too low). There's multiple important reasons why engines are set to idle at given rpm's. Proper Alternator voltage output is one of them.
Berry57
