BenJacobs
- Apr 5, 2026
- 1
- 0
- Location
- Saskatchewan Canada
- 2012
- 5.7 hemi
Hi everyone. Hope someone can shed some light on my problem.
I recently bought a 2012 ram 1500 sport with 200k (km) on it. I got it for a really good price and knew there was some problems.
The most annoying one right now is, when you drive at cruise or idle the rpm will dip slightly sending a annoying ping (chime). It recovers right away and you don't feel or here in in the actual idle. The battery tested weak so I replaced it. Cleaned and relearned the TB.
It currently has 3 permanent codes,
P0563 (battery voltage low)
P0032 (O2 sencors 1/1 heater cerc high)
P1524 (Oil pressure out of range)
These codes where before the weekend, it was overdue for oil change. I changed oil and oil pressure sencors just as a precaution. Also changed the battery, but have not yet read the codes again, will do when I'm back at work on Monday.
I hoped the rpm dip would have stopped, bit no luck. Any insight would be appreciated.
Regards
Regards
