Idle Speed
amora
5,7 Hemi
HI!
I have a 2007 Dodge RAM 1500 / 5,7 Hemi
When I start the Motor (cold) the idle speed begins with 1450 for 30 seconds, then 1100 for 20 Seconds, then lower.....
When I start the Motor (warm) the idle speed begins 1300 for 20 seconds, then 900 for 20 Seconds, then 600.
My question is, if this is nomal that a motor runs for so many seconds with such a high idle speed??
Thanks and regards
Alois (from Germany)
TheMaddog
DFW
Yes. You need to give the truck some time to warm up, get the oil warm too. And when it's already warm, that just means its idling at easier pace, because the oil and the motor are already warm and in the engine.
A
amora
5,7 Hemi
I would understand the high idle speed, when the motor ist cold. But why does the motor need when he ist warm.
And I think nowone waits one minute, till the idle speed gets slower - so that technical thing is for nothing - isnt it??
mountaingoat
Could also be a vacuum leak my truck only does it when its cold but mine is an 04 so it could be a little different
TheMaddog
DFW
I do, mainly because I put in my phone and pick out a song to play.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Seems alill long, wifes 05 with stock computer spikes on start up for 2-3 seconds and then settles into idle. Her truck cold idle is 800ish, my truck winter idle till warm is 850. Her stock idle is 500, mine 650.
truckin151
2013 sport
Mine takes a bit to warm up in the winter time, a few minutes max, but once you start driving and it warms up it drops down lower. Summer time it still does it just not as long
02blkram47
Lebanon, NH
2018 Ram 1500 Limited
My idle was like clockwork at 650 Tom's but lately its dropped down to 500 and its much rougher at that mark. Once it even stalled when it was down to 500. I'd like to get it back up to 650. Any idea how?
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
The high idle at start up is normal. Mine does the exact same thing and take a minute or two to get down to normal idle. Cold or warm engine alike.
A
amora
5,7 Hemi
Thanks fpr your informations
very very strange, that there are RAM's where the idle speed is like mine, and at others not
I will go next month to my dealers garage to check the control coputer, cause i am nerved, to put the frist gear, with an idle speed of 1300 and higher.
A
amora
5,7 Hemi
I want ot reset my PCM - perhaps this help.
Can someone help me?
Thanks
truckin151
2013 sport
Reset the pcm just pull the battery cable and let it sit for a couple minutes
A
amora
5,7 Hemi
What did the dealer say?
Swype-n from my Galaxy Note
we really don't have good dealers in germany. there ist no spezialist for dodge anywere. thtas the cause, I am writing here in the forum the home of dodge, in hope for help.
A
amora
5,7 Hemi
i was at an american car meeting. there were 3 rams 3 gen.
all 3 had an idle speed of 650 U/min after 20 seconds.
there was an mechanic, too - he said that it is not ok, that my ram needs 1 Minute to reduce the idle speed from 1400 to 650 U/min. But he could not say, what the problem is. I think my motor gets leak air!!??
SmokedRam
Zephyrhills, Florida
Does it surge at all? If not, try cleaning the IAC Valve....and give the TB a good cleaning.
Mine in park at 650 and in gear it will idle at 550.
