in dire need of help
briguy150
Hey guys i need some real help. I have roughly $8,000 into a stroker engine for my 2006 ram 2500. i ordered the stroker kit from pro power peperformance. Avenger race engines did the build. It has the very best of everything in it. The problem i am having is there is no fire on the #8 cylinder. The plugs, coil pack, injector, and compression are all good. I ordered the stage one tuning from hemifever. Not sure if i am having a cam compatibility issue or what. Does anybody know of a performance shop on the west side of michigan that deals with dodge. Please help! or if there is anybody around here i will pay top dollar i just need my truck running.
Dubstep Shep
Houston
2014 R/T
First of all, I would check with Hemifever to see what he thinks it might be. Make sure he has all the details of your build.
Secondly, I would double check EVERYTHING. I had a fueling issue when I put the new motor in my mustang. Turns out my fuel rail pressure sensor had a few wires that got cut when the motor was going back in.
B
briguy150
What are the telltail signs of a cracked intake guys. My number 8 cylinder was bone dry when i pulled my intake and the other 7 were soaked.
Kmiko
