Installl MOPAR safe in a Limited
Paulo
St Louis area
Ram
So we added the MOPAR safe (82215519AC) into our 2019 RAM Limited. Install is easy but the three screws that screw safe into back of console are a challenge. It`s a blind install, small area. Used a small drill Bosch Chameleon (great drill system) to get in there. Ease your pain, make small pilot holes before final drop of the safe. Recommend cutting out some foam to keep your goodies from sliding around.
Phillykid
Same basic issue for the Lock 'er Down box - just installed one in my '21 Bighorn console. not overly difficult to get the screws in place but does take some dexterity... Nice feature to have tho, regardless of which one you go with
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
That particular part number is not recommended for Limited or Longhorn trim levels because the tray sits lower, and you will lose the ability to slide it all the way to the rear. Did you find that to be true?
DB Cooper
Califor
5.7 ETORQ
Has anyone used a non mopar safe and installed in the center (between the seats) storage areas? I'm considering one of the gunvault.com options; I need a keyless operation. Curious what's under the bottom of the storage area and whether or not safe to screw into it?
HiramAbiff
sequim washington
Have A 2022 limited and yes they installed and you cant slide the tray now am wondering if you can cut the carpet and bottom out [f it would fit then
OasisNinjaBat
