Instrument Cluster and 8.4 Conversion (Flash needed?)
Aikido187
I am doing the upgrade from the basic instrument cluster with the 3.5 inch EVIC to the premium cluster with the 7 inch EVIC. I am also doing the conversion from a ra2 5.0'' touchscreen to the ra3 8.4'' touchscreen. Is a dealer flash needed for either one of these upgrades???
Buckeye2019
2018 Cummins
No flash needed. You will have to get the mileage change on your instrument cluster it has a chip in it that keeps the miles. Contact TVandNav2Go and he can change it for you to match your mileage
cgeorgemo
Joplin, MO
3.6 Pentastar
Your only need for a dealer will be to get an unlock code for the radio when you've installed it. Take the serial number to the parts counter before you install and they can look up the correct code for you.
Sent from my SM-N910P using Tapatalk
hankRam2015
Or contact nav repair if you don't mind paying. Either way works. Good luck
Karstensdad
Idaho
2016 ram 2500 Big Horn
Cummins 6.7
What is the price on the 7" EVIC miles correction?
GYSOT
2014 Ram 1500
That's what I did, easier to pay 20 dollars then for me to go up to the dealer etc. I am told all 8.4's when you change vehicles need the code.
GYSOT
2014 Ram 1500
My dealer wrote all my info down, I think he is making something for the door sill as well as noting in computer as my new one had zero miles.
Saleen5150
