Jim66
I have a 2004 Ram 1500 that shows "Lamp out". All lights, including cargo, third light, license plate, etc. At first I thought it was a bad ground as it would go off/on on bumpy roads and when releasing the brake pedal. I noticed condensation in the driver's side tail light assembly. After removing bulbs, I dried the turn signal socket with paper towels and hair dryer. I also inspected the light housing assembly and siliconed a gap where the lens had separated from the back of the housing. I also noticed the same side brake light bulb burned brighter than the passenger side. After changing both bulbs, the problem seems to be corrected. I'd seen this in several posts and thought I'd offer what fixed my situation. Thanks.
