scovie
Looking for help with this.. connect trailer to truck all lights works as they should but have no trailer brakes.. took truck side plug apart all looks good.. set trailer controler to 10 tape it on and went to back of truck in which it took at least 10 seconds or so till test light showed power going to trailer brake pin, which i would say means controller is ok? but when hooked to trailer there is no brakes... ground in truck side plug looks ok... when i put a block in cab to apply the brakes ( with brake controller in normal position ) i donot get power to the trailer brake pin in the truck side plug.. what am i missing here
