Jacking question
Matt Todd
Laurel DE
rookie question, don’t judge me...does anyone have a picture the jacking location to lift the front to change a tire? 09 1500 sport quad cab.
meedom
I use the same jack points as ram1500rsm....
PaulTGarrett
Grumpy old man
Tampa Bay, Florida
408 Cummins Turbo Diesel
I stick my Hi-Lift jack under either of the front tow hooks depending on the side that needs some additional clearance. For the rear I just stick my Hi-Lift into the trailer hitch and pick up the entire rear end.
(Does that constitute Hi-Jacking the thread? LOLOL)
TomB 1269
Schenectady NY
2019 Classic
I had always debated the use of the hitch as a lifting point on the rear of a truck. Has anyone ever had an issue with doing so?
Mbrigh3
IG: Stormtrooper_5.7
MD
Did someone mention jacking? Did Jennifer Lawrence phone get hacked again hahaha. Sorry couldnt help myself and my 5 finger friend hahaah
PaulTGarrett
Grumpy old man
Tampa Bay, Florida
I have used the hitch to pick up the back of a few of my vehicles, usually while offroad so I could stick cribbing under the tires to get myself out of a, um, slippery situation. It's a quick way to get some room under the tires to stick boards, rocks, tree limbs, whatever.
TomB 1269
Schenectady NY
2019 Classic
What about using it to lift the backup in order to place jack stands, etc.
PaulTGarrett
Grumpy old man
Tampa Bay, Florida
You can stick a Hi-Lift into the trailer hitch hole and jack up the entire ass end at once but it is SERIOUSLY unstable to do it that way. I wouldn't do it.
Get the Hi-Lift adapter that slips over the jack's tongue and has the two hooks that you can stick in the slots of your wheel. Pick it up, stick in a jack stand, go around to the other side and repeat. 1000% safer way to do the job.
