Keep your truck moving with Goodyear Commercial Tires
carid
Cranbury, NJ
Hemi 6.1
There are over 500,000 trucking companies in the US, with over 15 million trucks on the road. Tires are one of the main components of their performance, as they see miles and miles of roadways every day. They need to be durable, safe and provide a safe and efficient ride.
Choosing the best tires for your fleet depends on several factors, including overall longevity, fuel efficiency, retread capabilities, traction, and durability. Not only do commercial tires have the construction, rubber compound and tread design that is specifically designed for the way they're used, but they also ensure optimal load capacity for every truck type.
Look through our list of the most popular commercial tires and choose the best set for your truck.
#1. Goodyear Endurance
https://www.carid.com/goodyear-tires/endurance-lhd-527645412.html
Features:
- Dual-Layer Tread Compound for optimize treadwear and rolling resistance
- Shoulder wedge developed to help stabilize belt package and improve longevity
- New sidewall compound helps lower rolling resistance and promotes fuel efficiency
- Steel belt package helps provide enhanced casing toughness and durability
#2 Goodyear Endurance Trailer Tire
https://www.carid.com/goodyear-tires/endurance-wha-413564870.html
Features:
- Four wide circumferential grooves help deliver all-season traction on wet, snowy or dry roads in stop/start waste haul applications
- Dual-layer tread compound helps optimize treadwear and rolling resistance
- Deep 24/32" skid depth helps extend tread life in waste haul applications
- Steel belt and casing package helps improve toughness and endurance, offering improved ROI, retread after retread
kmrtnsn
Ventura
Probably a way bit extreme for half and three-quarter ton Rams, but Thanks!
Click bait, the above are big rig tires
you do realize that this is @carid sub-forum which they advertise regularly on, they pay for the ability to advertise which supports this forum. It should have been painfully obvious with a heading of commercial truck tires and referencing for fleet use. Ram 4500 trucks and above can use these type of tires
