keys and block
BAMA BOY
Gasden,Alabama
4.7 Liters of fire breathing fury!
anyone running aftermarket keys and then crank them up to make a 2 inch lift and a block in the rear ?
HemiBabe
DFW
I have had a few friends do that with Z71s, haven't seen or heard of any Ram's doin it... but I dont think it's too big of a deal. Might wear out the front suspension over time from bein cranked up, but I could be wrong... I'm sure someone will chime in soon with better info
quietpeen
2021 TRX
Hellcat
you could get the same result from just cranking your stock keys and save the money, but it you put blocks in the rear also you will keep the rake look.
BAMA BOY
BAMA BOY
Gasden,Alabama
My buddy did this with his z71 and he got 4inches of lift in front and a 2 inch block in the rear. Wish some one has tried this on a ram
HKkid
Missouri
What size tire are you wanting to run?
quietpeen
2021 TRX
Hellcat
you will never get 4" lift on the front of your truck with or without aftermarket keys. if you want that much lift, crank your torsion bars 2" to level the truck and get a 3" body lift.
BAMA BOY
BAMA BOY
Gasden,Alabama
Ill keep the 33s until later this year and ill go 35s and a body lift
HKkid
Missouri
Just crank your bars and run 35s...if you add aftermarket keys and then crank them I thinking your CVs are going to be maxed out.
BAMA BOY
BAMA BOY
Gasden,Alabama
My bars are cranked and that's what I was skeptic about
quietpeen
2021 TRX
Hellcat
ok, i see in your sig that you already cranked your t-bars....disregard my previous post telling you to crank them...LOL
Aftermarket keys won't give you much more and like HKkid said you will really be maxing out the cv anlge. With your truck leveled you should be able to run 35's and then add the body lift.
quietpeen
2021 TRX
Hellcat
Yea definitely..and that allows you to get the expensive tires first vs. adding body lift and rolling on small tires
HemiBabe
DFW
LoL, yeah that might look a lil goofy :crazy:
05ram
KY
I have aftermarket keys and got a 2.5 to 3in lift in the front. (did have to add 2in blocks in the back) I run 35's just fine and my cv's are maxxed! Any ideas on a 3-4 in suspension lift for these trucks?
BAMA BOY
BAMA BOY
Gasden,Alabama
I want a 6 inch just can't afford it just yet
05ram
KY
keys are by far the cheapest but will do damage in the long run.
schroederMP
Indiana
Cummins
Has your buddy blown any CVs? I did 3" on my chevy and went through CVs like crazy.
Dont go anymore that 2.5" of level in the front, or you will regret it.
BAMA BOY
BAMA BOY
Gasden,Alabama
All his steering components wore out of in a few thousand miles
geneseedennis
