Knocking noise
Griebz
Heres a question for the experts.. I have a 2015 ram sport crew cab w/ 11k miles on it. Two days ago i noticed a knocking noise in the steering wheel when i turn all the way to the left. I went outside and can here a low knocking noise which seems to be coming from under front drivers side of the truck. Only when the wheel is turned all the way to the left. No other symptoms , truck rides smooth as ice . Any ideas what it could be ?
Thanks in advance for the help
Peter Griebel
catch 22
right here
none
Maybe a wheel weight touching something? If you have lifetime rotate and balance on your tires, have them do it (just to see if the noise goes away).
Rustycowl69
2001 ram 3500
V10
is the vehicle 4WD? at full lock, while in 4WD you are fighting the u-joints in the front axle half shafts.
G
Griebz
Nope the wheels arent hitting anything and the 4 wheel drive isnt engaged. Its bizarre , the wheel is t rubbing or touching anything. Could it be inner tie rod or rack?
shane1981
millington tn
it is electric steering .it could be something inside the motor or the gears inside the assembly skipping teeth.they use plastic now days on stuff you wouldn't think they would
G
Griebz
Thats kinda what i was thinking.. It def sounds like its coming from the steering column.
atc06jh
Middle Georgia
Mine does this too. It never did it until after I leveled it. But when I turn all the way left or right and roll real slow, I hear a locking sound. I had the dealership tighten the brakes and add some high het grease to the pads. It worked for a little while, but its doing it again now. I just deal with it haha let me know if you find a good fix though, cause it is a bit embarrassing.
G
Griebz
Haha im just going to bring it in in 2 weeks.. Ill def let you know what they dont find lol. Im sure theyll say its normal or " could not duplicate".
G
Griebz
Only difference is mine does it when its stopped.. Forgot to mention
G
Griebz
UPDATE
Truck needs a new Rack... Wtf. Gotta be honest, this is really making me question my decision to buy a Ram. 50k truck less then a year old should NOT need a new rack
MR.Z06
Banned
UPDATE
This is exactly why I bought the lifetime warranty. Look at the history of reliability of Chrysler and it's parent company Fiat. They are both among the worst in the industry.
If you plan on keeping the truck longer than 5-6 years I'd strongly recommend looking into it.
G
Griebz
I figured the 4th gen rams were solid now, mark improvement in terms of quality over the earlier years.. This serioulsly ****** me off
MR.Z06
Banned
I can't believe I'm saying this but it's kind of like a Range Rover. Beautiful, nice to drive, comfortable, capable, I mean air suspension for crying out loud!
But reliable. No.
Expensive to repair. Yes.
Rustycowl69
2001 ram 3500
V10
oem size tires? "leveled"? lifted? lowered?
G
Griebz
Nope.. No mods what so ever. Side steps, mudflnflaps and bed cover.. Thats all
Rustycowl69
2001 ram 3500
V10
well, that is discouraging. I know it is not recommended for any steering system to run it to full lock and hold it there. Are there any physical stops built into the knuckle to prevent turning too far? My old 76 Power Wagon had adjustable stops in the steering knuckles.
G
Griebz
Not sure.. I never usually turn it to full lock.. Just so happened i was backing into my driveway and heard it through the steering wheel.
