LA 318 4speed- 360 magnum need some info
Ramlife1234
Thunder Bay ontario
Got an 1988 truck with a 318 tbi motor... np 435 trans... 4x4... wondering what is needed to swap in a 2000 360 magnum motor. I’ve read online that bellhousing is the same. Read that I will need a magnum 360 flywheel to balance engine... will the stock 318 wiring harness work? Can I leave the stock tbi or would it be better idea to switch to a carb... know I will need an intake either way... anyone who has done this swap some help would be appriciated.
muddy12
Indiana
Is there some reason you can’t keep the multi port injection that’s on the 5.9?
