leaking from behind glove box
jawsla503
There is a air leak type noise behind my glove box and i cant figure out what it is. I even pulled out the glove box to see but could not find anything. Does anyone know what it could be?
HemiBabe
DFW
Welcome to RF.
I'm sure someone will chime in soon.
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
maybe a crack in the duct work for the a/c?? Welcome to THE forum lol
Droid Incredible 2 on the move!!
Mad Cow
Anchorage, AK
Cummins 6.7
Welcome to Ram Forum. It could be the door on the vent system. I bet it is that.
bigbadram1500
Springfield, IL
Welcome to the forum. :) The only thing I know of that's around the glove box area there is the recirculating door, as JT mentioned above. Could be stuck open maybe? Not sure.
J
jawsla503
It happens whether the heat/ac is on or off and its a high pitch sqeal and it will constantly do it
quietpeen
2021 TRX
Hellcat
welcome....so it happens even with the fan turned off?
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Does it happen just while moving at certain speeds, or all the time no matter what?
J
jawsla503
Happens all the time even if I'm in park with the engine off but with the power still on or when I'm drivin down the road
J
jawsla503
It will even happen with the key turned to acc
J
jawsla503
Actually it will only do it in acc after I started it then shut the truck off until I open the door
BlackedOutHemi
DFW, Texas
2012 & 2012
So it's something with accessory. And it sounds like air being forced through a small opening?
J
jawsla503
Actually it will only do it in acc after I started it until I open the door
J
jawsla503
Yeah just not on acc tho basically all the time but yeah it sounds like an sir leak it will squeal for about 10-15 sec then stop for 5 then it will do it again
J
jawsla503
Edit
Reticle918
