Lets look at lights. JJ lights Vs: Factory!
sullivan
Houston, Texas
Yeah, projectors + HID's make a worlds of difference. I love mine. Nice vid
ltr450rider13
Those are just what I need. Temperature rating?
LB3711
Trumbull, CT
3.6L V6
cool but you didnt put the highs on at all
Musclemckeester
Houston, TX
n/a
n/a
Nicely done man.
So that's just with headlights...your fog lights were off in both cases?
Laramie1997
Laramie1997
Springfield, Missouri
1997 Ram/2013 Charger R/T Super Trak Pak
5.2 (318ci)/5.7 (345)
Actually, I did... I'm just running factory halogens for the highs and you can't see them all that well in the clip.
damn you!!!
:naughty:
Nicely done man.
Actually.... If you watch very closely, I cycle through the high beams and fogs on the clip. They are just hard to see against those HID's. LOL :roflsquared:
Musclemckeester
Houston, TX
n/a
n/a
Ah ok, so you've still got the stock fogs. Just curious. That is a lot of light output for just the headlights. The heads projected and fogs HID'd.....well I bet that output could be seen from space. :drool:
EJM05
Somers, CT
440 Big Block
Yup. I have the hid fogs. And when I use those with my hid projector headlights... no need for high beams.
quietpeen
2021 TRX
Hellcat
ok, so explain this to me like i'm dumb(well because I am).....the projectors are your low beams right? In the quad heads is the lower light your high beam then? So if you want better high beams in a jj light you have to get HID's for the high beams?
LB3711
Trumbull, CT
3.6L V6
You don't have the bi-xenon setup?
Butch you can either have just hid lows and halogen highs.
I have the bi setup. Which is low hid and high halogens but when I hit the highs a metal thing that makes the cut off line moves out of the way and turns the projector into a flood which puts the light above the cut off line also. It makes great light on dark roads. My highs still go on but you can't see them much but does provide some light faint but there.
I hope I explained it well or JJ will correct me.
Sent from my AT&T iPhone 4.
LB3711
Trumbull, CT
3.6L V6
Hid highs are not needed. Not sure about hid fogs either yet. Someday I'll test that one out. I'm surprised how much usable light the fogs throw off. When the hid lows are off that is.
LB3711
Trumbull, CT
3.6L V6
Get 5k's it will be so much better.
Arturo Rojas
