Leveing 2014 ram 1500 4x4
CUBS_WIN
Im gonna install mevotech upper control arms. Do i need to change the factory shocks or can i just use a spacer on top of the strut? I know 13-14's have ball joint issues whick is why im installing the mevotech. Do i also need to do anything to the rear? I know people are changing front shocks and using bilstien 5100. I dont go off-roading...its just my daily driver. Please help...lol. Thanks.
Sent from my SAMSUNG-SM-G920A using Tapatalk
bgray
Canada
This should be in lifted section. However....
You can run a leveling kit spacer, but the bilstein 5100 is a much nicer setup. Set at 2.1" they ride nearly identical to stock. If your truck is close to 60,000miles your OEM struts and shocks should be replaced anyways, so might as well take advantage of that
CUBS_WIN
CUBS_WIN
Im at about 35k miles....lol
bgray
Canada
Id still replace em regardless. Leveling spacers are pretty lame
CUBS_WIN
CUBS_WIN
Ok...thanks
CUBS_WIN
CUBS_WIN
So will i need to do the aftermarket upper control arms...i know 2014 have the ball joint issues
Syntec
Eh?
H5.7
if you set 5100's at 2.1" then no... however if you decide to set Bils 2.8" forum members will recommend to upgrade UCA's (Zone ones get lot of love on here)
Depending on your budget, if you can spend on beefy UCA's I would.
CUBS_WIN
CUBS_WIN
I just didnt know if i can do the mevotech uca and spacers to level it and still use stock shocks without having issues with the ball joints like the 2014's are know for.
Hemi 5.7L V8
Don't know where you picked up the bad ball joint knowledge of 2014's but it seems to be drilled into your head lol.. Plenty of people, including myself are running Bils at 2.8" with stock UCA's and have no issues
ameer73
