Lifted 2wd with front control arms issue
othmax
amman
Hey everyone, I'm new here!
I know this issue might be common, but I’ve been searching for a solution for a long time with no luck.
I have a 2017 Dodge Ram 2WD running a 6-inch Rough Country lift kit, and I’m facing a problem where the upper control arms (UCAs) are making contact with the coil bucket.
I’ve already tried a few different aftermarket control arms, but I keep running into the same issue.
Has anyone here actually found a fix for this?
Has anyone tried using a spacer at the ball joint or some kind of custom modification that helped?
Any advice or experience would be really appreciated. Thanks in advance!
Nick@GotExhaust
Supporting Vendor
SC
Could the control arms have been mounted on the wrong side of the truck ? Seems like I heard something similar awhile back.
Might be time for some measurements.
I would confirm this!
G-Ride990
Administrator
Chandler, AZ
5.7 No E-torque
I don't think yours are on the wrong side. Those air-ride link nipples are supposed to be on the front the control arm as far as I know. (circled in my pic)
I think we need some more pictures of the rest of the lift kit to help you out.
Nixonjgreg
