Level Driving/Fog Light, Missing Part
Noble Six
Cleveland, Ohio
I have a 2016, and it still has the stock fog lights. I've seen this asked before awhile back, but there were no responses. The leveling wing nut on the driver's side is missing, and I can't adjust it. Does anyone know the thread size, or know where I can pick a replacement up/order one? Rather not put new light in, just for a levelling issue.
diymirage
Banned
Not a clue but if it were me, I'd pull the nut off the passenger side and take that into the hardware shop to at least figure out the thread and hopefully find one that works
Unless were talking about a 60s A body, there is no way left and right side nuts arent the same
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Logical suggestion has been provided,
however Google also gives an answer....
The fog light wing nut adjustment on a Ram 1500 is typically a 10mm metric size. This is a standard size and will require a 10mm wrench or socket to adjust the fog light position.
