Level my truck
Rick7812
Clanton, Alabama
5.7 hemi etorque
I want to level my 2022 bighorn 4x4. I purchased upper control arms 68323530 AA and 531AA along with Bilstein 5100 B8
0-2.6 adjustable shocks. The actual height difference between front wheel well 35.75: and rear wheel well 38" = 2.25".
Is that the correct snap ring location or should I go down 1 ring to 1.7"??
CanuckRam1313
Ontario Canada
2023 Warlock
You can set the 5100's to either 2.1" or 2.75" raised.
If you want a little front rake, then set them to 2.1".
If you want max extension, use the 2.75" setting.
You may need to then raise the rear springs up 1" if you use the highest setting so you don't get the california lift....lol
