Leveling a 2014 2500
ForceofWill
2014 2500 CC Trades
This is straight from RC website, 2.5 leveling kit recommends 33's... I think 35's would fit without the kit, but that's why I asked
One other question, with the spacers do we need longer shocks? Or will the factory ones fit the extra up travel?
That's gotta be a mistake on their part. My stock tires are nearly 34s. Dunno what they're thinking.
The front bilstein are like $75 each. Worth it to me over spacers. Honestly doing all 4 shocks was the best money I've spent on this truck. The ride is 100x better.
Ratket
Arizona-
didn't you have to use the spacers and new shocks? to acheive a lvl
shocking14u
2003 Ram 2500
Diesel
I am a huge fan of the Bilstein 5100 series shocks for any truck! There really is not much of comparison for the money.
Built a 2014 Ram 2500 2 weeks ago with new coils and Bilstein 5100's all the way around and it worked awesome.
Ratket
Arizona-
so it's not lvled? or is it leveled? did u just get bigger springs to lvl it?
Ratket
Arizona-
did u use after market coils or a spacer to get it lvl in the front?
shocking14u
2003 Ram 2500
Diesel
I used a 2.5" leveling coil from excel suspension with extended length Bilstein 5100 series on this particular truck.
I have also used maxtrac coil spacers with Bilstein 5100 shocks and they worked well also.
But the leveling coil was much better performance wise than the spacer.
ForceofWill
2014 2500 CC Trades
Did you keep the stock spring rate?
shocking14u
2003 Ram 2500
Diesel
The spacers of course keep the stock spring rate.
I am not sure about the leveling coils, as I dont have the ability to test them stock vs. lifted to check in/lbs.
I do understand however that most providers of lifted / leveling coils go up a minimum percentage over stock rates in order to support the higher center of gravity and to improve handling. Not to mention, most of my customers want that when upgrading to a lifted coil along with a better shock that can handle it all, which we have found to work well with the Bilstein 5100, and several other premium shocks.
ForceofWill
2014 2500 CC Trades
I feel the front is sprung pretty well stock and was just making sure those longer ones weren't softer.
I'm happy with the spacer for my application. I feel we have enough travel with the bilstein. That being said I'm not rock crawling with this thing.
slim072590
New Mexico
Alright so one more question... going from stock to 35 12.5 with 4.10 axle gears and the 6.4 hemi, how much power am I going to lose?
Will it be like going from a 4.10 to a 3.73?
Or more drastic like 4.10 to 3.55?
I like drag racing people I work with, can't go from champ to chump, lol
SETEX 6.4
Port Neches, TX
I think it will be fine. Probably feel more like a 3:73
I plan on doing the same thing when my stock tires wear out!
regularcab2500
Buffalo
5.9 Magnum
33.5" is the stock tire size so going up a little over an inch wont hurt you much..if i did my math correctly your effective axle ratio would be 3.92 so right between the two options
regularcab2500
Buffalo
5.9 Magnum
Well i have 3.73s so i know they arent bad lol..the only change i wanna make to the drivetrain thus far is 4.56 gears and i expect 35s will be a perfect fit with a level :naughty:
slim072590
New Mexico
damn, guess it's time to buy the leveling kit and tires
So what about fender flares? What's everyone doing there?
regularcab2500
Buffalo
5.9 Magnum
Im gonna get some oem flares so that with 35×12.5s on factory 20s the tires bulge ever so slightly past them
ForceofWill
2014 2500 CC Trades
Where do you get the OEM flares. I'd like the Bushwacker ones but not for over $400
regularcab2500
Buffalo
5.9 Magnum
I was probably gonna order them through my dealer so i can have them painted max steel to match
Mopar site has them for like $370 and theyre black like the power wagon ones but they are able to be painted..
