Bramic71
Good evening everyone. 2022 Ram 2500 6.7 4x4. Serviced the transmission. Replaced fluid and both filters, and also installed a thermal bypass valve. I could only get the transmission to around 160° on a mile and a half run up our steep road in 2nd gear. On the highway it maxxed out between 145° and 150°. I checked it at 160° and it was still a little lower than the lowest "hot" hole on the transmission dipstick. Being that the transmission fluid temp will be running cooler now, when it's at 160°, does it still need to be in the "hot" range on the stick? Thank You All
